Hi all,
I have a gsx with a compustar alarm system. To start off the siren no longer works, I will explain why. Alarm brain has brown wire for siren and green-white for parking lights. The brown wire is getting no power, I checked via amp meter. So using the siren wire (brown), I tapped into the green-white because when the car is in panic mode the lights flash that will cause the siren to chirp. All of this came together perfectly accept for a small problem. Now when I turn my lights on with the switch on steering wheel, the siren comes on and stays on until I turn the lights off. I drove around for a bit chirping the siren at hot girls but other wise annoying and I can't drive at night. If any one has any idea how I could power the siren off the green-white lights cable without the siren going off when I am using the lights, that would be great.
Thanks
Darvesh
Thanks
Darvesh
