1 - 10 of 10 Posts
teddygram
hey everyone, does anyone know if there is a difference between a non-abs portioning valves i.e the year of car it came off of. I just did a abs delete on my AWD talon. Do you think that could make the brakes drag? thanks
I can't remember where i saw it "may have been VFAQ.com" but there was a chart somewhere that showed the difference in front to rear pressure between different 1G models and GVR4 between awd, fwd, turbo, n/a ect. Sorry i couldn't help more.
If you can, raise the car on some jack stands and see which wheels don't spin freely. Once you find out which brake(s) are dragging, try to crack open the bleeder screw on the that peticular wheel, and see if the wheel frees up.
Frees up: hydraulic issue.
Stays the same: locked up caliper or slides.
1 - 10 of 10 Posts
