1 - 4 of 4 Posts
217talon
So I finally got the transfer case filled up and just took the car for a quick spin. The car vibrates worse then ever if I start to get above 25 mph! I also installed a DME camber kit. I pressed the new ones on and they were straight. This car is beginning to be a ******* joke again!
Any Ideas?
IF this is a driveline vibration from replacing the carrier bearings, Did you reinstall the carrier bearing shims(washers) back in the correct location when you put the prop shaft back into the car?
Get a magnetic angle finder and check your driveline angles. The shafts should be sitting the same angles to one another. If not you'll need to shim the carrier bearings to get them to be the same.
Are you sure you replaced the drive-shaft in correct phase?
1 - 4 of 4 Posts
