If you read the thread a little further down, my car is in limp mode. I going to pull the codes uses the pulses as listed in the sticky above, but my multimeter seems to be broken, even after I replaced the fuse. So today I pulled the TCU completely out of the car.
Is there a way to test it when it's out? I opened it up and all the capacitors look good. There's nothing that gives off any concern. I read on Tuners site that you can test the voltage on the "center pin", but this means nothing to me.
Help.
Help.
