Only had my car for a short period so not sure what has and has not been done. I recently took the stock pcv off and cleaned it out with carb cleaner and made sure it clicked inside. Prior to all this i noticed quite a bit of oil in my intake pipe as well. Since then i have installed oil catch can on the valve cover vent (non pcv) and routed it to my intake pipe. Tonight i noticed anytime i went into boost right after i let off and lightly touched the gas it would blow blue smoke out the back for a couple seconds then stop.
I dont think it could be the rings as it only burns oil under full boost not all the time. Could it still be a bad pcv after cleaning it? or do i need to look elsewhere.
