I just recently purchased a 97 gst with 125,000 miles on it. When I bought it the guy that sold it to me said it ran real rough and that u could smell unburnt gas coming from the motor. When I got it home and pulled out the plugs they where black as could be. So to see what it would do I bought a new set of plugs and those blacked out after letting it warm up a little.
When I start the motor it has trouble starting. It'll turn, chug and repeat once or twice before it'll turn on. Once it's on it'll idle real low, like it's barely above 0 on the tach. When i try and rev it it'll jump like 500 rpm up then act like its gonna cut off before i take my foot off the gas. If I do this to or three times then press the gas slowly it'll crawl to between 4 and 6 grand before it sounds like it's backfiring and then bog down again.
I have done a compression test and it read between 170-180 across the board. I hope I did it right cause It was my first time doing it. Things I checked are the coil pack and the tps. The coil primary resistence read .3 on both leads. Where I read it said the norm is .75 anything else to replace, but it still runs, so I was wondering if the sence of extra fuel could be from the coil not firing hard enough to burn it all.
Thats all for now but if anybody could help me out i would be very grateful. This is my first turbo car so im a little lost on working on it compared to a n/a motor
