Re: Hard to start hot/cold
Running rich can be caused by a couple factors. But the change in temperature and the car running worse in cold conditions throws a red flag on one part in particular. The MAF or air flow sensor, whatever you want to call it probably isn't sending an accurate relay signal to your ECU. When you replaced it, did you purchase a new or used part? You need to get that tested.
As for Modulator Kits? I don't really hear anyone using that term a lot, and I think that may have been a reference to componets of your fuel system. Fuel Filter, pressure regulator, pump, etc... If you are postive fuel is going through your return line, then most likely your fuel system is working correctly. I am going to assume your car is mostly factory parts, and you were not trying to upgrade componets of your fuel system, like bigger injectors. That will also cause you to run rich, and for your car to not run properly.
So I think you see what I mean, I can think of a lot of things that are causing the symptoms of your problems, but until you fix one thing at a time, and you're sure you have fixed it correctly the first time. I will recommend that you go to a mechanic who can fix the car for you.
