1 - 12 of 12 Posts
For the 100 it would cost you to buy a new known pump, you are probably better off just ditching an unknown and doing yourself a favor.
I know that doesnt answer your question, but Its not enough monitary gain to take the risk IMO.
If nothing else, the filter style screams stock to me.
Shott is right. Have an adjustable fuel pressure regulator (AFPR) installed before (or quickly after) you install the 255.
FueLab and Aeromotive are the most popular brands.
These can cost around 200 or so, but prevent your car from running rich at idle and part throttle situations.
I am planning on just putting in a wallboro 255, 550 or 650cc injectors, wideband, fmic, get mass airflow sensor tuned out plus full tune, 3' exhaust all the way back with a dynomax bullet, two racing cam shafts, lifters, 3' downpipe, tubular manifold, electronic boost controller, I already installed a after market boost guage, plus suspension and a racing transmission I want to run no more than 18-20 psi.
I just got this car running right, the timing was off by a tooth and there was a huge exhaust leak, now that I got it running smooth I can start building it.
I need to review this site before i get started though to see what parts will fit the bill, I want to keep it a sleeper.
1 - 12 of 12 Posts
