My '90 Laser 1.8L 5sp is giving me trouble.
First and foremost the battery is overcharging and boiling through the vent caps. I'm hoping to address that ASAP.
I put 200 miles on the car after my recent tune up and it drove fine until now so I don't think it's something I messed up. Plugs all looked good when I pulled the old ones. I cleaned the MAF with throttle body cleaner at the same time.
This problem I'm having now is probably (hopefully) linked to the battery issue but here goes...
Last night while sitting in traffic before getting on the interstate my idle went from 700rpm to about 1500rpm and then kept going up and down between those two every few seconds. I figured maybe a vacuum leak had happened or if there's an IAC valve maybe it's going bad... I also questioned the coolant temp sensor because I know they can do crazy things when they go bad.
I then get on the interstate and drove 40 miles. Once up to 65 mph the only way to maintain speed or accelerate was to give the pedal a very light pressure. Too much pressure and it seemed to bog/dump the fuel and the car would actually slow down.
I also noticed when I got off the highway that there's about ZERO throttle response above 3,000 rpms. It's like at 3,000 no matter how far my foot is on the pedal or what gear I'm in, the call falls on its face really bad.
No check engine lights, car is not overheating, and I don't think the clutch is going bad because no matter what above 3,000 rpm there's just no power/response whether I'm flooring the gas or I'm light on it.
Help?
Help?
