1 - 14 of 14 Posts
93GSX5SPD
I was browsing ebay looking for a used hot side when I stumbled across an adapter flange to bolt an evo 8-9 turbo on to a dsm manifold. Now I have no desire to do this but it did make me wonder if any one has tried this part. Imo the routing of the intake piping would be a pita. None this less I always find discussing this kind of stuff interesting.
http://cgi.ebay.com/ebaymotors/DSM-Mitsubishi-4G63-1g-2g-Turbo-Flange-Adapter-EVO-8-/130398509318?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e5c5b5906
It's an adapter flange, I.E. no moving parts. It would be fine to use.:rolleyes:
Ya but is it really going to fit is the question..
No, normally people make parts for specific applications that dont work at all. :rolleyes:
Its been done, google search. And why would the routing be a pain? May be easier to use an external gate though. From the pics I have seen of the EVO 8 turbos, they fall straight down on the cold side anyway.
Not really worth the extra work when there is a gazillion turbos allready available for the 4g we use.
The turbo from the EVO 9 has a 10.5CM hot side on it compaired to "our" 7cm. There is a massive difference in the flow numbers Sleeps. The flange design on the EVO's is 1000 times better than the one on our belovid DSM's.
-Shane
Stock for stock I can agree fully, but is it better than anything aftermarket that can bolt up to our application? Pound for pound is it better than what is available?
-Shane
Can't forget twin scroll too....
This will null it's bigger size and help with spoolup.
Well all know everybody loves Evo parts on there DSM but This is a Great idea for someone that wanted to do the work and not just go with said 16g/18g/20g
What would make it even more interesting is a EvoX Turbo Adapter haha
I totally agree with you on it not really being worth it. But When I saw this it got the gears turning in my head. I've got a friend who has one of these laying around and I know he's the kind of guy to try this type of thing out. Now that I saw this pictures of the dsm on tuners I guess the routing wouldn't be bad at all.
-Shane
Hes exactly right which is why this would appeal to some one with one of these turbos laying around.
If you have the money and time I think it would be cool to do. Just to be different and rock much newer designed turbo. Thumbs up, Id try it if I had one lying around.
How is an adapter flange made which effectively adapts a reverse-rotation twin-scroll turbine housing to a manifold designed for a standard-rotation single-scroll turbocharger?
Either you're going to need to mount the turbo so the inlet is on the driver's side of the car (completely illogical) or install a half-rad so the turbo will sit where the rad should be in order to make this work effectively. Either way, we're talking about way too much work to install a 16G on a DSM.
If you try installing it with the inlet facing the passenger's side, you'll end up with something like this:
1 - 14 of 14 Posts
