1 - 20 of 34 Posts
newdsmman
Discussion starter · #1 · (Edited)
FS: DSMLink V2, V3, JHRacing, ETS 5", Built Motor, Built Head, Tial, 2GAWD Fuel Setup
Alright, selling alot of spare and current parts to fund my new setup.
Most of this stuff has very few miles. Alot of it is 500 miles and one test and tune night. Some of it has up to 3-4 miles on it. Nothing has more than 4K miles because I have not drove my car 4K miles in 4 years.
Contact:
Message me here
or
dsmer1 at live dot com
or
4Seven8 2Nine7 29Six5
Motor
I am willing to sell this as a short block - Long Block or whatever. LMK what you are interested in and we will work something out.
Short Block
500 miles since rebuild
Compression tested at 180 182 182 180 after 500 miles.
Turbo 6 bolt block .020 over
JE pistons .020 Over
JE Rings
Eagle Rods
Factory Mitsu OEM Crank
ACL Race Main and Rod Bearings
Balance Shaft Delete
Mitsu OEM Front Case/Oil Pump
All internals balanced within .1G
Mitsu Forward Facing Oil Filter Housing
All new Mitsu Seals, Gaskets, Oil pickup
Water Pump and lower timing cover included also
N/T oil pan w/-10an bung welded on front can be included but is beat up some
$1000 OBO
Head
1G head
SuperTech Dual Valve Springs with proper locators, proper tip height etc... Spent some good money at the machine shop - 500 miles
Supertech Ti Retainers 500 miles
BC 280 Cams 1000 Miles
3G Lifters
Light smoothing work done to intake and exhaust sides
Fresh Resurface, valve job, guides etc - ready to bolt on and go - Head is perfect!
$700 OBO
Between the two:
ARP L19's
500 Miles - One Tq Sequence
Brand new APR Lube Included
Craftsman Laser Etched 14MM 12Pt Deap Socket included, I have only used this socket to TQ these head studs, so it goes with them
$150
Fel-Pro MLS 1193-1
Brand new Sealed In Package!
$180
Can Split Up or sell all togather
You decide
Mitsu Knock Sensor
500 Miles
Perfect
$35 OBO
Gates Racing Kevlar Timing Belt
If I remember correctly Gates makes the kevlar belts for HKS and Greddy
Anyways, its a great belt - Good used sondition
2000 Miles
$35 OBO
THERMAL RESEARCH & DEVELOPMENT 3" Downpipe Back Exhaust
I have owned this for several years, but not alot of miles on it
This exhaust is nice and sounds mean -people have always asked about it for as long as I had it
The flange that bolts to the cat was cut off before the pipe necks down. A piece of 3"pipe was welded in to eliminate the neck down and the cat all togather. This exhaust bolts directly to your downpipe.
$350 OBO
2G Non-Cruise Throttle Cable
OEM Mitsu - 4000 Miles
Delete your cruise Control!
$40 OBO
Black Top Cam Angle Sensor - CAS
Working Perfectly!
$35 OBO
Greddy Turbo Timer with 2G Plug and Play Harness
This is a Black Turbo Timer - It is several years old and works perfectly
Simple and easy to use, has 2 presets times for easy operation
All wiring and plug and play 2G ignition harness included - install this in 10 minutes
$40 OBO
ETS 5" Thick Bolt On FMIC for 2G
I had them custom make this for me. It is pretty awesome. I have not seen knock since installing this.
It is 5" Thick! I replaced a SSAC FMIC kit with this and it bolted on in a half hour!
5" Thick Garrett Core
3" Charge Piping - Mild Steel (Alot Stronger, wont bend like Aluminum)
All piping Powder Coated Black
Flanged for Tial 50MM BOV
Setup For GM MAS - Comes with 3.5" GM MAS and couplers!
Comes with all T-Bolt Clamps
All Piping is bead Rolled
The 90 Degree Silicone coupler comming of the turbo is a 2.5" to 3" 90', So it is perfect for any down firing turbo with a 2.5 outlet (all S covers)
The coupler at the TB is a reducer to bolt onto a 1G NT TB.
This is the one, FMIC Kits like this rarely are FS, Jump on it!
Comes in the original ETS Package it was shipped to me in.
$1000 OBO
GM 3" MAS's and (2) 3.25" to 3" Couplers with (2) T Bolt Clamps
3" GM MAS $15 Each - $30 for all 3
Couplers and Clamps - $15
$40 for all of it!
The Best Boost Leak Tester
This is a Home made awesome boost leak tester
It is a 3" pipe with a cap welded on and a air nipple welded into that
It has a bead welded around the end so the included couplers WILL not blow off
4" to 3" reducer Coupler
3" reducing coupler for stock turbos
inline air pressure regulator - with this you can hook you air compressor line directly to it.
I have tested my system to well past 50psi with this tester. DOES not blow off.
$35
13" Perma Cool 2650 CFM Fan and 10" No Name Electric Fan
This 13" perma Cool Fan is awesome!
2650 CFM by itself
This is setup as a pusher but can be reversed as a puller
This alone cooled my car, I added a 10" ebay fan because I had it and I am paranoid. The 10" fan is off other than at the track.
The Perma Cool Fan is over $300 new by itself
http://www.summitracing.com/parts/PRM-19113/
http://shop.perma-cool.com/HD-Electric-Fan-13x3-3-4-3300-CFM-19113.htm
$80 OBO
FIC 1600's
2000 miles - Perfect - New Seals from FIC 500 miles ago
$200 OBO
2G AWD Bolt in Fuel Setup:
This starts with a modified 2G AWD Fuel Pump/Sender Assembly, It has a 255 Walbro in it and a -8an bung welded to the factory outlet. The Siphon for the saddle bag tank is also already drilled to the perfect diameter.
-8an SS Line leaves the pump/sender assembly and goes to the frame rail mounted 044 inline fuel pump.
The 044 Pump is mounted to the 2G body with the provided clamp. -8an SS Line leaves the Second pump and heads up to the engine bay. It meets the Summit Inline Filter (-8an fittings and new SS Filter for E85). -8an SS line leaves the inline filter and goes to a factory rail with a -8an port welded on. There is a bolt on -6an outlet/return line port on the other side and a -6an SS line to go to your FPR.
This setup is boss for Race Gas and pretty good for E85. I could run about 30psi on my 67mm on E85. If one were to use a new 400lph pump inplace of the 255 im am sure this setup would be more amazing. best part is, it all bolts right in.
Most or all fittings and line is Russel.
No fabrication requiered, no fuel cell in your street car.
$500
JHRacing T4 True Divided Twin Scroll Manifold with Duel 38MM Wastegates and 3" Downpipe
Less than 1000 miles
Perfect Condition
This is a VERY heavy duty manifold - Thanks again Jake
Increased sppol times over my old HKS Divided Cast T4 manifold.
Both Wastegates included, they are no name but both have Tial Valves and Springs (Both are Lg Red and Small Red Springs - 17psi)
Both Wastegates have a fitting for -4an line
3" Downpipe included to bolt to factory exhaust location (2G) - It is not pretty but it works perfectly - bolted up to a Garrett 6776 and a PTE 6765 perfectly
$800 with wastegates and exhaust OBO
Discussion starter · #2 ·
Re: FS: DSMLink V2, V3, JHRacing, ETS 5", Built Motor, Built Head, Tial, 2GAWD Fuel S
Aeromotive Fuel Pressure Regulator
All fittings included
-6an in from rail
A push lock fitting is included to use with standard replacmet hose for the stock return
-4an male fitting for vacuum or a barbed fitting
$150
JMF Race SMIM
Very nice - Some light scratches
Ordered new with (6) Vacuum Ports
2000 Miles
$380
K&N Air Filter - 4" ID inlet - Big Mo Fo Ver - Brand New
I got this to make sure I had as much air flow as possible. I never built the intake.
http://www.summitracing.com/parts/KNN-RE-0860
$35 OBO
ThrottleBodys.com 63.5mm N/T TB
500 Miles
Uber boost Seals
Max Shaft - I broke a half shaft, that mod is not worth it. Steve at TB.com did me up a new one with some special strong shaft. This is there top of the line TB, every option. All the vacuum ports on the top are jb welded shut.
I have pressure tested my entire charge pipe system to over 50psi, this tb holds it like a champ.
$165 OBO
AEM 5 BAR MAP Sensor
Very Nice - 2000 miles
Comes with Pigtail (not pictured)
$100 OBO
Nice Valve Cover with (2) -10an Bungs
Perfect Valve cover - no cracks or leaks
500 Mile old EVO 8 Mobil 1 Oil Cap
(2) -10an Aluminum Bungs Welded on - Baffles in tact
$125 OBO
Spark Plug Wire Cover
Custom Piece I bought on this board
Very cool and clean look
Stainless hardware included
$25 OBO
Pictured Above with valve Cover
-10an Moroso Catch can Setup
500 Miles Old
Black -10 Pushlock Hoses and Black Fittings - One extra 90Degree Push Lock fitting comes with this, it is unused (not pictured)
Moroso Catch can with Black -10 fittings
$125 OBO
2G Ksport Coilover Suspension
2000 Miles - Clean - Nice - Complete
Looking to trade for stock struts plus cash. Stock strut condtion does not matter. I do not need springs as I have my stockers.
Will get pics up soon
$Make me offers!$
JMF Coil Pack Relocation Bracket with Coil Pack
This nice little Aluminum Bracket mount to existing holes under your intake manifold. it is nice and tucked away and looks really clean
The coil pack is included. This fired BPR8ES's gapped down at 65+ lbs/min
$50 OBO
Taylor '409' Race Core Spark Plug Wires
These are perfect for a DSM. These helped me maximize my stock system and looked fantastic doing it!
Awesome Wires!
$50 OBO
1G Fluidyne Radiator
Stock fans will not work on this
The Best Radiator for your 1G
Will fit a 2G if you move the stock bottom mounts
In good used shape
$125 OBO
Tial 50 MM BOV
Original Box included, - 7psi spring, perfect for low vacuum/med to big cams
Original unused fittings included, I ran AN lines for my vacuum that is why you see that fitting in the pic.
$150 OBO
Jay racing Alternator Relocation Kit
2G Mitsu Alternator
Upgraded Steel Mounting Bracket - The Aluminum one breaks, this WILL NOT BREAK!
Power Steering Spacer, bolts and original belt that came with kit included even though not pictured
$100 OBO
Turbo -10 Oil Returns - Two
-10 SS Line with (2) 45 degree Fittings - I have used this on T3 and T4 setups
-10 Posh Lock Line with (2) Straight Fittings - Due to the flexability of the hose and the short legnth of the fittings this is really easy to fit and looks great. I used this with a T4 Setup on a JHRacing Manifold
$20 Ea. OBO
Hallman Evolution RX Kit - Red In Cabin Boost Controller
This has the ceramic ball and a light spring for fine boost adjustment. Those are included but I have the heavy spring installed for high boost. This works like a champ. It comes with the -4an fittings installed. I bought these fittings and sent them to Hallman to have them machined for proper operation.
This comes with the 72" Standard Cable - uncut so it can fit anything and you can cut it to legnth. For me the 72" worked fine.
As you can see it comes with everything it came with new including the box
$140 OBO
FP -4an Inline oil Filter with Fittings/T for Oil Pressure Gauge
This is a Black FP but it is for Journal Bearing Turbos as it has a .100 orfice
500 Miles on oil filter
This is how i ran my setup so I could monitor oil pressure after the filter into the turbo. Included will be everything to run fron the oil filter housing to the inline filter, then a T fitting so all you have to do is screw your 1/8th NPT Sender in and a line out to the turbo. All these lines can be customizable
This was a bunch of dollars in fittings and everything plus the inline filter
$80 OBO
-4an Vacuum Line Setup - Another Boost leak source eliminated!
Never blow one of these hoses off!
This was all the lines I needed for my BOV, FPR, (2) Wategates, Boost Gauge
It comes with 6 Lines w/fittings made for my car. These can be customized for your car.
It also comes with 6 more lines and extra fittings. There is a Male to Male to Swivel Female T fitting that was $35 bucks alone!
$90 OBO
2G Gauge Pod Cluster Trim
$10 OBO
2G 3 Pod/Triple Gauge Trim
$10 OBO
Pro Sport 52mm Premium Electronic Oil Pressure Gauge - Amber/White
0-150 PSI
3000 Miles
Comes with original box
Very nice gauge. It can change color Amber or white. It has a warning beep, flash or beep and flash and you can easily set it up to warn you whenever or not at all.
$50 OBO
Pro Sport Electronic Fuel Pressure Gauge Amber / White - 52mm
0-100 PSI
Comes with original Box
Nice Gauge
$20 OBO
Summit Racing Digital Water Temp Gauge
4000 Miles
This in includes the sender
http://www.summitracing.com/parts/SUM-G2984/
$15 OBO
StewartWarner 40psi Boost/Vacuum Gauge
Has fitting on back for -4an line, can be removed
It reads 1psi when off - other than that works perfectly
Lines up good with my AEM 5 Bar MAP Sensor
http://www.summitracing.com/parts/SWW-214542/
$30 OBO
AEM Wideband Gauge
Comes with all original packaging
Comes with all original supplied gauge faces and bezels
3000 Miles
Works Perfectly
NEVER used Leaded Fuel with this setup
SAVE MONEY!
$135 OBO
Fluidampr 4G63 Harmonic Balancer - P/N 630702
3000 Miles
Has some cosmetic knicks from being installed and having my water pump belt 'walked' on
Comes with original Box, materials and packaging
$210 OBO
2G ECMLink V3 with 2G GM MAS Direct Cable
All original packaging and documents included
Clutch Cut cable included
Perfect!
$450 OBO
2G GM MAS Direct Cable Extra $40
2G DSMLink V2.5 and Socketed Eprom ECU with Keyspan Adapter and Laptop!/U]
Plug and play setup! Ready to plug in to your car. Chip in ecu and ready to go!
ECU Socketed by JestrTuning
V2.5 Comes with adapter, cable, and USB cable
Keyspan Adapter Included
Gateway MX6960, 1.83 Core 2 Duo/1GB/160GB/DVD+RW. I bought it new around late '07 and it is fairly beat cosmeticaly. Parts are cracked a little here and there but everything works perfectly. It has built in Wi-Fi also.
Perfect for a tuning laptop! Battery holds a charge very well and the OEM charger is included.
$350 Without Laptop
$100 For Laptop by itself
$425 For Everything! OMG!
Contact:
Message me here
or
or
I would like the gates belt, The 2g gauge cluster, Knock sensor, and spark plug wires. Pm me a good deal shipped to Canada.
(4) BFG Drag Radials - 215/45-17
They have one track day on them and were not launched hard.
The have some minor feathering from the rear end squating but it very minimal.
They are mounted on Talon 17" OEM wheel. I will sell the wheels for extra money but I would prefer to remove them from the wheels for the sale.
$320 OBO For the tires
Timing belt
Head
L19s
2G Cluster Gauge pod
Wideband
Fan Setup
-4an line setup
Sold
I'm gonna take the kn filter. PM me your paypal address.. I will also provide a pre-paid UPS label you can print. Thanks
Save
Discussion starter · #9 ·
Pic of KSports:
By request:
This was pre install
They are near mint, some scratches from tools at most
Frank has been around for some time and attends Import Showdown all the time. Thanks for the good score on some parts!
This guy is legit. I bought some stuff from here and his tranny and T case. :D
Save
So much win in this thread for me. If I could only afford everything I want to buy.
Couple questions:
1. Would you be willing to separate the cams from the head? If so, PM me a price on the head.
2. Definitely interested in your gauges, particularly the boost gauge and water temp.
We can talk more via PM.
Save
Couple questions:
Head and cams were sold to me.
Discussion starter · #16 ·
Tru story as posted above in a list of sold parts. I have a updated list of sold parts also. I reply to pm's pretty quick so PM me because alot of people are asking about gauges and, well, everything.
Thanks for all the kind words guys.
Dibbs on the Tial BOV if it hasn't sold already. PM sent.
Save
Discussion starter · #18 · (Edited)
I can not modify a FS post on this board so here is the current sold list:
Alot of talk on alot of other items but this is what is sold now.
Trans
T-Case
Scatter Shield
PTT Clutch/Accumilator/Line Setup
Tial 50MM BOV
Jay Racing Alternator Relocation Kit
Boost Leak Tester
K&N Air Filter
DSMLink GM MAS Cable
AEM Wideband
-4an Line Setup
Fan Setup
AEM 5 Bar
Head
Cams
L19s
Thank you everyone. There is a TON of super awesome stuff here to get also, so get on this list!
To anyone that does not know me it is because I have been more quiet the last few years with the family... I have been around these DSM parts for years and have made alot of good friends. I have also sold ALOT of parts through multiple differant setups of my own and I sold lots of decent DSM budget parts. I sold alot of SSAC FMIC kits and exhaust systems, wastegates, different cast manifolds etc...
They know me as 2gAWDTalon on DSMTuners
long story short, I have been around and I ussually have great stuff for sale, as is the case now!
Thanks for the space!
Discussion starter · #19 ·
SOLD LIST:
Trans
T-Case
Scatter Shield
Tial 50MM BOV
Boost Leak Tester
K&N Air Filter
AEM Wideband
-4an Line Setup
Fan Setup
AEM 5 Bar
Head
Cams
L19s
Fluidampr
255lph Fuel Pump
K Sports
Short Block
Valve Cover
Catch Can Setup
Triple Gaugle piller Pod
Taylor Spark Plug Wires
Thermal Research & Devolopment Down Pipe Back Exhaust
GM 3" MAS (4 Total) and Couplers
Greddy Turbo Timer
Water Temp Gauge
Oil Pressure Gauge
Fuel Pressure Gauge
Hallman Pro RX In Cabin Boost Controller
1G N/T 63mm TB
BlackTop CAS
Super interested in Eprom ECU and V2.5. As long as its a legit copy(Have proof?) and the ECU is in good working condition, I'll take it. My pay pal is ready. Let me know. Pictures help.
notice Text sent.
1 - 20 of 34 Posts
