I have been trying to get my Car started after a head gasket and timing belt job. For some reason the thing is getting no spark. To test for this I pulled a plug, connected it to an old spark plug and watched for arc. No spark on any of the 4 wires. I then continued to investigate and replace the battery, wires and plugs. I checked the coil and the resistance appears to be alright. I then went on to testing my Crank position sensor and noticed that back probing the ground terminal (on the connection) and the ground (bare metal on block) that I measured a resistance of approx 1000 ohms. Could this explain my no start issue? The starter is kicking (and motor is turning over) and I have already checked the clutch depression switch. Also I found this connector unplugged and after many google searches can not figure out where it goes and what it is. Thank you in advance for the help.
