1 - 13 of 13 Posts
dsmtrance
The guy I bought the car from said he put ARP head studs in. When I take the valve cover off tomorrow how will I be able to visually tell that they are, or are not, ARP's? What should they look like in comparison to the stock head bolts? Thanks!
Discussion starter · #9 ·
GOOD NEWS!!!!!
Took the valve cover off and I DO have ARP studs! I checked the torque on them and got up to 105 ft-lbs and just said forget it. The guy I bought the car from must have torqued the shit out of them! I also did a comp test. BUT, first I have a question. About 8 months ago I did a comp test at my friends house with his gauge and we got 180 psi across the board (JE 9.0:1 Pistons). Today, we did another comp test w/ my new Pep Boys $50 comp tester and I got 195 psi solid across the board!!! GREAT!!!!!, I'm pretty sure. So needless to say I chalked it all up to a shitty stock cooling system (CHECK MY OTHER POSTS FOR A RUNDOWN ON THE SITUATION I'VE BEEN DEALING WITH). SO, I have ordered a Fluidyne radiator and a set of Spal High Performance fans. I also switched to a 180 deg. therm. So I guess we'll see!! I'll let everyone know how it goes! THANKS
Ok guys I am working on replacing my head gasket and I just want to make this totally clear for myself. What size allen wrench do i need? The manual says I need a 13mm and i hear from alot of people you need a 10mm. So which is it? Because i have my motor all torn down ready to take those bolts out and pop the head off. Manifolds out of the car, timing belt, water pump all off. But I have been endlessly searching for a 13mm allen wrench for like 3 days now. I want my baby back running again! Thanks for the help guys.
Dennis
ok so I finally got my head off and heres what i found out. The head bolts were 8mm. And I dont remember what size the nuts were that held in the whole valves, springs, camshaft assembly. But it was something relatively small. (within the normal socket set range) But I dont remember it being 13mm.
Well, the head is off now to the machine shop to be rebuilt. Also my car is a 1.8L so im sure its probably different then the specs for the 2.0. But I think that the head bolts are 10mm for the 2.0 if anyone needs that info.
Hope I could help.
Dennis
OK
ok,
I fiddled around with some allen wrenches and it seems that the outer head bolts (10 black) are 10mm but the inner head bolts (3 or 4 metal colored ones...cant remember exactly how many and I dont have the thing in front of me) are 13mm.
Seems I'm still on my search...
1 - 13 of 13 Posts
