Hehe, I saw this thread before there were any replies yet and just shook my head and laughed.
There has been some good points made and some unproven speculation thrown around, AGAIN. Go figure.
And once again the results thus far are the same people. The FP Green turbo has supported runs in the low 10's.
The MF1 line has not put down solid numbers yet. Why, I don't know or care. I myself got a MF1 L3 turbo, did as much of a freakin review as possible with the track here being closed. I'd give my left nut for the track to open today to put some damn numbers up here for everyone that can't seem to find the search button for this same topic, geez. Hell, if I had got a Green, the track would still be closed, hehe.
I've posted my spool rpms and psi, do a search and compare to what the Green spools at.
I won't sit here and say get an ETA32, simply because I have one. In fact anyone that's been here for awhile knows EXACTLY why I got one. That job is unfinished and unfortunately will remain that way until the track opens, May 2nd. As mentioned above there will be no sugar coating, only the details and a slip. Good or bad, no excuses.
If someone with supporting mods asked me today which to buy, I'd say get a Green without a doubt. I base that only on the numbers proven thus far, not one thing else. If someone asked me if I thought they could runs 10's on a Green, I'd say, "Nope." And I base that one only on the fact that if you are asking, you can't handle a Green. Fact! If I'm wrong, I say prove me wrong.
Let the hype cease, until the numbers can back it up. Period. Keep your pie-hole shut unless you got a mf1 equipped dsm's timeslip and all the details!
As for me, all I can say thus far is that the eta32 impresses me and I'm confident that it'll take me where I want to be, much easier than a 16g would. I really like the fact that I was able to run only 10 psi (because of a slipping clutch) and got no boost creep on the internal gate. I also love the 21 psi of boosted grin on 91 octane pump gas I get daily. I consider it's spool-up perfect. 550 injectors maxed on pump gas. 24 psi and zero knock sums on a simple 100 and 91 octane UL mix of 2:1. The awd is downright squirrely with a good launch on a decent road. A local member rode in and drove my car and said the difference over his 16g'd Eclipse was huge and absolutely noticeable. Those are the real facts thus far as I know them to be.
And I'd still say get a Green, based on the numbers...
