1 - 3 of 3 Posts
speedytalontsi
looking for alittle help well advice. below are the mods i have and the best time i ran last year at rt.66 in joliet illinois on a 65 degree night. what can i do next was thinking small or big 16g? do they make that much of a difference or no? what can i do to improve traction? now i set the profec to 8psi just in 1st and then in second turn on the high to 18psi. what can i do next alttle advice would be greatly appreciated. is this a good time for a fwd with these mods, i know an awd would be faster but am i in the ball park
this should prolly be in the gen tech section.
look into the phantom grip lsd thingy to get better traction in the first gears. a small 16g will create wheelspin all over the place. also a set of coilovers or at least adjustable shocks would help alot. by setting the rear really stiff you'll eliminate some of the rear squat tha causes problems with traction.
1 - 3 of 3 Posts
