1 - 5 of 5 Posts
turbs
Im in the process now of changing rear hub assemblies($170.00 ea.) on my 95 tsi awd due to bad bearing upon inspection while doing a 4 corner Powerslot rotor upgrade, Im having a bitch of time seperating the hub from the splined shaft on the outer CV axle in the rear. I have ruined the threads of the axle on one side and Im waiting on new pair of rear outer CV axle shafts and nuts from dealership ($174.28 ea). as well as new front hub assemblies($97.48 ea.)
Does anyone know how to seperate outer cv axle joint at the outer CV boot?
also can you reinstall the axle and hub and rotor without the backing plates which have the pebble/dust rotor shields spot welded to them?
I cant seperate any of the components because the rust weld is so bad, I dont even know what Im going to do about all the ebrake hardware that i cant get off. I wouldnt recommed trying this install if the vehicle has been through winters and salt. I have now around $1300 in just parts and ~$100 on shipping invested to a project I thought was a powerslot rotor upgrade. Any idead/help would be great, last of parts to arrive today for more fun.
Discussion starter · #2 ·
has anyone had to replace their outer cv axle joint when changing wheel bearing/hub assembly in the rear?
im wondering if the fronts are going to be this bad
this has turned into a very expensive nightmare, and
much harder than I thought, not to mention no car
for a week now waiting on parts which must have
arrived today. this sucks!
uuuuhhhh... maybe Satan isnt so bad after all.
Geeeesh!!!
i am pretty sure my cousin had the same problem in his 95 tsi...where in new york are you located..he brought his to an axle place they rebuilt the one that was in the spindle and got it separated also... the place is in hempstead new york
Im upstate (ithaca)
I have the replacement axles (outer cv joints) I just really need
to know if the entire assemble can go together without those backing
plates. I dont know if anyone understands me, the car isnt here and
im going off memory from friday before last. it looks like i will need to use the backing plates (plates behind rotors) that the rotor pebble shield is spot welded to.
to anyone who doesnt have these shields such as with a big brake upgrade,
did you just cut the shield or eliminate the entire backing plate from the
reassembly?
1 - 5 of 5 Posts
