1 - 7 of 7 Posts
CrisMurfy
Hey hey. My damn drivers' side window keeps getting looser and looser. At first it was only when you closed the door that it jiggled back and forth, and then it was when you drove really fast with it 1/2 way open. And now when it is 1/2 way open, the bass from my subs makes it shake violently. It is so annoying. I have been trying to deal with it for a long time, but I just can't take it anymore. I know this as probably happened to a lot of people, because I have been in a lot of eclipses that have the same problem, but I couldn't find a good thread about it. Any ideas on how to tighten it or somehting? Thanks. I will try any gueses anyone has, so anything will be appreciated. Thanks.
No Ideas?
Sorry man. My bad. It seems like the trim at the bottom of the glass is getting pulled further and further away. The gap between the 2 sides of the trim (where the glass is in the middle) is pulling apart. This allows the glass to shake back and forth. I hope that explains where the problem is. Thanks.
-Ok, the trim is only held in with 5 screw and a lot is nylon clips, if those clips are worn they will pop out, you can remove one clip and check with your auto part to see if they have any. Or get some Velcro, cut to small 1" strip and put them between the clips, this should solve your vibrating trim.
Thank you very much. I'll give it a try.
1 - 7 of 7 Posts
