Some people here were waiting for me to get this installed and tested:
Just installed it last night. Did not have but an hour to test it very late, now up on 3 1/2 hours sleep. Dog tired....But lovin it.
VERY preliminary reults and still need to do some more logging, testing, and tweaking.
With Water-Alky and 18psi running hard to redline from 1st thru 3rd EGT would top out at 900c-920c and 8-14 knock counts/or higher if ran hard back to back (damn AZ heat)
With Propane and 18psi running hard to redline from 1st thru 3rd EGT tops out at 800c-820c ZERO KNOCK ZERO ZERO ZERO
That is a difference of 1652F to 1472F. Almost 200 degrees F. And yes, I can FEEL the difference.
It's the difference from running on the edge of the temp danger zone to way below the danger zone.
You are totaly unaware that the system is working, totaly feels just like you motor is working without any aids. Never at any point do you feel anything "Kick In". Just smooth power at any RPM and any PSI.
I wasn't sure if the system was working actually, so I shut it off (switch in cockpit) and bam, the temp rose 100c turned it back on and she dropped again
More to come later
More to come later
