Centre Force Dual Friction is the worst clutch...lasted 7 thousand miles...its complete crap.
The AWD is a '90. It's probably only making about 250 at the crank,tops. 16 psi, 3" Thermal, no cat and opened air can with a K&N. The axles, and center diff. broke under agressive launches, the clutch forks did not. If there was a CF in there I believe the axles and center diff would have stood a better chance of surviving these launches but then again I'm sure the CF would wear prematurely.elhalish said:Frontdriver, what year is your AWD and how much hp do you have under that hood that broke all that? Did the parts break under aggressive launches or just from day to day driving?
Ah, that must be why I only got ~50K miles out of mine.rainy said:Centre Force Dual Friction is the worst clutch...lasted 7 thousand miles...its complete crap.
