First off, the price for this information will be that you take pictures of the procedure as you do it, and that you email them to me so I can do an official writeup. email me at
pious@houston.rr.com (my name is Patrick). Also anyone who reads this and uses the information (I have tons) must agree to collaberate with me and others who do these mods. I hate it when people take the info I give them...improve on it, and come back saying they will charge everyone for their services if someone wants it done. With that said, here goes:
I've done this on another radio for much the same reason that you are willing to mess with this one. You will need super wide angle blue LEDs that run about 10 dollars a piece. Ask yourself is it worth it? You may need 7. I'm going to open up the infinity head unit somewhere down the line, so you can wait on my lazy azz to get around to it or just go for it. The LCD looks backlit and I'm willing to bet that there are incandescent lights behind the buttons that have a orange bulb rubber diffuser. The bulbs are closest to the 3mm bulbs found in the link I will post below. They will most likely be diffused by a clear plexi lens right behind the black ABS face. The LCD will probably have a bulb off to the side of the LCD.
You can either use a wide angle white NICHIA LED and slip a blue/violet piece of acetate paper behind the Liquid Crystal element or you can attempt to replace the bulb with a blue one. That will require some experimenting to get it right. Without adequate diffussion, all LEDs will betray a hotspot in shallow surfaces.
You will need:
a) Good products
- L121CB1K-3.5VF (3mm) Wide angle Blue
LED for the radio button backlighting.
They can be had at:
http://www.netdisty.net/ds/L121CB/
- Try these for backlighting the LCD:
RAB362B2K (Sideways illumination)
http://www.netdisty.net/ds/rab362/
or
FiberOptic Sheets (These are cool):
http://www.lumitex.com/lcd_backlighting.html
or just get the LED that lights up the optical sheet:
Nichia model #NSPBF50S Don't go by the mcd reading
because the wider the angle, the lower the mcd rating
will be despite the amount of light it's putting out:
https://trorderonline.thomasregiste...D=17700&ItemID=3611817&Navigation=DetailsNav.tpl&BuyerSelection=ItemDetails.tpl
b) Good reverse engineering skills
- First, have your code handy. Start by taking off the face. These things are usually screwed on with overlapping tabs on the unit's side. Remove all the knobs that are on the front (should be 4). Look for 4 tiny screws and several black snaps that are part of the face (all 4 sides should have a couple). Don't worry, it shouldn't fight you too badly. If the face isn't attached to the board, you should see the bulbs. You are going to have to remove one or crush it so that you can hook it all back up and test the voltage supplied to the lamps when it's on. I usually determine the power connectors so that I can do this at my bench using a drycell battery to test the results.
- Once you have verified the line voltage on the board (it my be 12v, but you must verify this) you can now calculate the resistor size.
http://linear1.org/ckts/led.php (you'll owe me feed back for all these free links!)
