21 - 40 of 45 Posts
Blackboost said:
LOL!!! I am serious Martin it did got the job done. :D
Ha, ha... Seems like you bought my old car!
jrotten,
Your system would work, but the problem is that you'd also lose the volume of the fuel entering the rail, not just lower the fuel pressure.
Discussion starter · #25 ·
ya its basically a fishtank valve.... but why would you do that on a honda? it would just bog down the wussy little motor. and it basically does exactly what a nice shiny $100 one does.
cause more airflow needs more fuel
i've heard of plenty of turbo cars zip-tying the return line at the track
how's it make for daily driving? any adverse affects - mpg?
-aaron
Discussion starter · #27 ·
ya i know more air flow needs more fuel, but we are talking about NA honda here. how much more air flow can one of those get??? anyways, to answer your question..... as for daily driving it hasnt caused any problems. but if you close the valve all the way you will see some nice black smoke along with a high idle speed. i leave it most of the way open untill i go to the track. then i pinch it down almost all the way and i can get away with a few more psi.
Will this work for my setup? Running a stock fuel pump + rewire + stock injectors? How much more of a benefit do you think? I could boost more, but it's only a t-too small that I have.
over 16 the t25 is pretty inefficient, much higher is pretty pointless IMO
better to run leaner on 16psi then dumping in fuel to cool hot intake wif more boost
-aaron
Discussion starter · #35 ·
-aaron
exactly..... if you got a bigger turbo (t-28 or so) i would help then.
Pics were not viewable. Please repost. -Thanks
21 - 40 of 45 Posts
