I was wondering if anyone knows the measurements for a 7cm turbine housing or how far you need to port a 6cm housing to get the right a/r ratio so I can use it with a Big 16G. I've seen a 7cm and 6cm housing setting side by side in a pic and have some idea on what needs to be done to the inlet and outlet ports but I've seen nothing for the inside of the housing where the wheel sets. I'm assuming something needs to be done to the inside right? I've done a search on this and a lot of people said they had a problem with the housing cracking when they ran high boost (over 20 psi) and it also kills power above 5000 RPM cause the a/r is way to small.
I want to do this cause it's an extra $200 for the 7cm housing and I would rather put that toward something else if I can.
Thanks,
Rusty
Thanks,
Rusty
