kinda of hard to tell from that view, only thing i can say is keep on eye on it make sure its not leaking if its not then dont worry about it,if if does leak you can do the "poor man's fix" add some JBWELD to it wont leak after that.. or you can yank the tranny and have a shop weld it for ya.. there does look like ther is something leaking around that area though i would check the entire bottom good before ya take the tranny out you may need just a rear main seal...
get a couple of cans of engine degreaser or equla and clean the under the car good and check for leaks etc the next day or two..
good luck
