I dont understand it....
The transmission in my car was rebuilt about 4 months ago. I never knew how it drove after the work since I havent had it 4 months yet. When I go into gear I know its in gear because it will feel like it grabs funny in the shifter or linkages somewhere. If it doesn't do this going into first then i am usually still out of gear. Untill now...
Tonight I pulled the tranny fill plug because The seal on the transmission cover is leaking a bit so I wanted to top it off. I think it was about 1 qt. low on oil!! After i filled it, i let it sit for about 2 hours to level off. Put plug in and started it up to take for a spin. (also shifter is mounted to the floor...no bushings.... was like this when i got it) It seemed to go into gear a bit smoother and doesn't grab weird anymore really. Just once in awhile. I have not drove it for awhile too so i might not be usto it again yet. It seems to pop out of first gear MORE often now. It might be because I cant feel the grab really....? Anybody have any ideas?? When i filled the trans back up, the old oil looked (the shit that came out) kind of burned.
ONE MORE QUESTION!!! Will vaccume pressure be higher on startup or after its warmed up??? Thanks
