Ok there is a HORRIBLE screeching bearing noise coming from the front case side of the engine... it has 6k miles on it because it has just been rebuilt.
Symptoms:
- Doesn't squeel at ideal
- Builds and maintains boost as well as it ever did
- Squeels over about 2k rpm whether in nuetral or on the move
- Has oil pressure
- Dosent overheat
What I have replaced:
- All timing pulleys/idlers
- Checked intake side of turbo, no shaft play!
What am I thinking?
- Spun bearing inside block (balanche shaft bearing??)
- Will it do this if the timing belt is too tight?? (even though I measured it and its within deflection specs)
- NO FREAKENT CLUE WHAT ELSE COULD BE WRONG!!
Please help me out guys I need my car for the snow!!!
Symptoms:
- Has oil pressure
- Dosent overheat
What am I thinking?
