I just got a 3in Gm maf for my ramchargers translator, should I take the honey comb part out? or will it ruin it, let me know
Wow that is pretty badass. That along with an RRE FMIC would be sweet.jprescott said:Dejon does offer UIC pipes for the stock sidemount location..
http://www.dejontool.com/DSM-1g-SMIC.htm
I think he also offers pipes to accomodate a blow through GM MAF for FMIC's.
Hope this helps.
Thanks, but I already got a set of dejon pipes on the 2Gjprescott said:Dejon does offer UIC pipes for the stock sidemount location..
Hope this helps.
I haven't really heard of any factual gains, but a lot of opinions. Most people think blow through would be a better idea becuase the turbo wouldn't have to pull the air through the maf sensor because it'd be a restriction and would cause spool to be slower. Having it in blow through also eliminates alot of metered air boost leak problems.Bifkin said:i'm thinkin i'll probably switch to the GM after i do my exhaust....
is there any difference in using the blow-through setup, as opposed to keeping it where our stock MAS is? aside from being able to vent to the atmosphere.... (which doesn't have any inherent gains, right?)
Like stated before, GM guys do it all the time, and they have been messing with them long before it was thought up to put a GM MAF on a DSM. It's been done for a while now, and obviously been done for a reason. The aftermarket MAFS are nothing but a less restrictive casing, same sensor and all.Kwik GSeX said:Have some actual dyno numbers before & after the screen was removed before you go ahead and give that kind of advice..
