quick question, will a 1990 fwd turbo tranny work in a 92 shell with a 90 motor, i blew my trans, and found a 90 cheap, please respond asap thanks lot in advance..
will 90 fwd turbo trannt work in a 92 shell?? help asap
Ya know... I'll bet this topic has been answered 10,000 times here and a very quick SEARCH would have yielded your answer quickly. This stuff is also covered in the VFAQ's too.
Yes you have to or he wouldn't have mentioned it. You'll also need the transfer case too and make sure you get the little tranny bracket with the cables and that shifter. They're all different for '90.
BTW - going to '90 trans, shifter and cables is kind of going backwards. The '91+ stuff is better.
ok, for some reason the search button never works, it always comes up server to busy or some shit, and im am fwd and will not need the t case, if the search button worked i wouldnt have posted this, thanks
posts
2.3M
members
104K
Since
2000
