1 - 7 of 7 Posts
MiNiONTSI
{0} Rpms: 3137 Prs/Vac 0.0 O2: 0.09
TPS: 36 Dc:19.39%
Timing 14 Knock: 0
Fuel(pw) 7.42 Hz:0.0 MPH:0
{6} Rpms: 4015 Prs/Vac 0.0 O2: 1.0
TPS: 102 Dc:65.07%
Timing 8 Knock: 11
Fuel(pw) 19.45 Hz:0.0 MPH:0
{13} Rpms: 4611 Prs/Vac 0.0 O2: 1.0
TPS: 102 Dc:84.57%
Timing 7 Knock: 14
Fuel(pw) 22.01 Hz:0.0 MPH:0
{22} Rpms: 5019 Prs/Vac 0.0 O2: 1.0
TPS: 102 Dc:94.18%
Timing 8 Knock: 15
Fuel(pw) 22.52 Hz:0.0 MPH:0
{33} Rpms: 5615 Prs/Vac 0.0 O2: 0.97
TPS: 102 Dc:100.6%
Timing 9 Knock: 13
Fuel(pw) 21.5 Hz:0.0 MPH:0
{42} Rpms: 6023 Prs/Vac 0.0 O2: 0.97
TPS: 102 Dc:101.48%
Timing 10 Knock: 11
Fuel(pw) 20.22 Hz:0.0 MPH:0
{53} Rpms: 6462 Prs/Vac 0.0 O2: 0.96
TPS: 102 Dc:97.84%
Timing 8 Knock: 18
Fuel(pw) 18.17 Hz:0.0 MPH:0
{55} Rpms: 6524 Prs/Vac 0.0 O2: 0.96
TPS: 102 Dc:65.4%
Timing 8 Knock: 17
Fuel(pw) 12.03 Hz:0.0 MPH:0
got knock.. but what's up w/ the speed? still at 0, or are you just not logging it? Are you revving, or what?
I SHOULD NOT be knocking at such low boost with and upgraded pump.
I do have part throttle knock too so I think something is up.
The only things that I can think of right now are:
1. MAJOR boost leak (i have an UIC pipe)
2. Clogged injector
you're really rich in the 4k-6k rpm area too. get an s-afc to tune your car.
look at the o2's. 1.0. You can be knocking from being very rich too as far as I know. Try upping the boost a bit to lean it out a little. Post the results. :)
1 - 7 of 7 Posts
