Are Idle Speed Controllers the same in the 1g and 2g turbo cars?
The 2G ISC (black plastic case) is an improvement over the old 1G (metal/tan plastic case). It has a higher ohm rating for the coils at around 40 ohms/coil. This means it requires less current from the ECU coil drivers, which means your ECU is in turn using less current to do the same work in operating the ISC.Red1991TSI said:They're interchangable but they're not the same. The ohm specs are a little different. I've used a 2g ISC before and encountered no problems.
