Not correct. The n/a throttle body is the same exact bore size as the turbo. It is 4mm bigger on the inlet, but necks down to 64mm i believe at the plate. I use one currently on my car, It is working excellent. the inlet inside diameter is almost perfect match for 2.5in piping, so it gives it a better transition. I purchased a 45 deg bend hose and it is working excellent. It is bigger and less dramatic of a bend than a 2g elbow. Hope that helps. Nate
