Where do i buy an ssautochrome 2g kit for around 300 bucks ive heard it mentioned on here before
If it doesn't line up right then the installer is trying to put it on backwards. Simply flip it over and I'm sure it will fit correctly.osyris379 said:The pipes did not line up and I ran into a ton of issues with it. You get what you pay for IMO.
UM NO, please stay out of a conversation if you don't know what you are talking about, thanks, bye bye now.xxtremes33 said:its not the kit itself that sucks, its the intercooler that are "crap." i havent had a buscher kit but if you put a ebay intercooler next to a good intercooler like a precision or greddy 2 or 3 row , youll see why the ebay intercoolers are not that great. the fin design and densities are far superior on the "good" intercoolers. but depending on what you want out of your car, those ebay kits and intercoolers are more than sufficient most of us, including myself. and theyre sure as hell better than our sidemounts.
Oh is that all I have to do? Wow, thanks for the amazing insight. I never would have thought about that without your help.robcatch said:If it doesn't line up right then the installer is trying to put it on backwards. Simply flip it over and I'm sure it will fit correctly.![]()
Show us a pic of your's and we'll tell you what you got. I've never heard of anyone having too much problems with it. Also are you talking about the lower or upper ic piping? With or without a SMIM? What turbo setup? If a 16g what J pipe; short route or regular? There are too many variables to even begin to try to blame the product.osyris379 said:Oh is that all I have to do? Wow, thanks for the amazing insight. I never would have thought about that without your help.
Anyway, when installing these pipes I tried every possible permutation and none of them lined up just right. I expected there to be some fab but not so much that I would have to cut about 5 inches off a pipe. I'm just guessing that I was given a 1g kit when I should have got a 2g kit.
No matter. It's on and I'm very happy with it.
You do realize the amount of times this "crap" product has been proven, Right ?xxtremes33 said:its not the kit itself that sucks, its the intercooler that are "crap."
Exhaust temps do run high on these. Rotarys can be beasts. If its running too rich, unburned fuel will actually light off still as its passing through the down pipe. Tuning lean increases these temps even higher. Its possible to read EGT temps 12"-16" from the exhaust ports in the downpipe and still see 1700-1750 degrees farenheit. EGT probes don't last long at all. Especially if its a street car.1gawd4g63 said:What do you mean rotaries produce too much heat? The combustion temps are relatively the same, the temp of the charged air is the same out of the turbo as a piston motor, you are spatting some incorrect information here man. You got an egt gauge on that rotary?
Are you talking about Ebay intercoolers in general, or the SSAC kit? It seems like you are talking about Ebay FMIC's. If you are then we pretty much agree with you. Sure some people have had success with a regular Ebay FMIC but they are definitely notorious for their poor quality. SSAC being an exception. Do you actually have experience with specifically the SSAC FMIC?xxtremes33 said:"crap" = so called crap. i wasnt specificly saying that they are crap myself cause theyve had a bad wrap. maybe i came across wrong. but truth of the matter is put one against a precision intercooler (garret intercooler cores) youll see the difference. my precision is much more efficient than my ebay core, period. have you run both yet? cause i have. maybe intake temps arent as important on dsms but on rotarys its crucial for making reliable power. in MY case, my precision dropped intake temps of about 10 degrees average over my ebay core on my rx7 running a haltech standalone ecu. not to say its the same for everyone else. actually i never said anything bad about flow rates, pressure drops, temperature variables between inlet and outlet passing, burst strengths, etc. cause as far as flow rates are concerned the ebay core probably flowed about as well as my precision and pressure drops were very minimal. my ebay core has held up great. the craftsmanship looks great. works great on my talon. i have NO complaints about my ebay core. theyre just not as efficient as i would like for my rotary. rotarys just produce too much heat for me to chance it.
I've never seen egt's over 1,650 out of a rotory myself, and noever had any problem with glasspacked mufflers EVER.harry99GSX said:Exhaust temps do run high on these. Rotarys can be beasts. If its running too rich, unburned fuel will actually light off still as its passing through the down pipe. Tuning lean increases these temps even higher. Its possible to read EGT temps 12"-16" from the exhaust ports in the downpipe and still see 1700-1750 degrees farenheit. EGT probes don't last long at all. Especially if its a street car.
Most mufflers on RX-7's use steel wool packing as the exhaust temps run so high, fiberglass packing and some other materials will actually burn out in a matter of miles depending on the tune.
What changes are needed to make this kit work on a 1G? Main thing I'm concerned about is the position of the inlet and outlet on the FMIC, the rest isn't too difficult.1gawd4g63 said:For a 1g this one is great.
