Hey guys and gals. I'm John and I'm into originality. With that being said, I want something original. So what does that lead me to? A 2.4L! Ok ok, it may not be that original, but it will be fun:thumb:
That's the list I just drew up in the last couple of minutes, I'm sure I made a mistake somewhere.
My Goals
The car is a 97 GSX - it will be my daily driver; literally DAILY driver as it is the only car I own. It must be mostly reliable. It will see the strip only a hand full of times a year, it will see road courses a few times a year, and I may do autocross with it. My power goal is at least 400 horsepower at the wheels on 93 octane (pump) and a conservative tune.
With that being said, here is the list.
Engine Block:
4G64 Block
4G64 Crankshaft
Eagle H-Beam Rods
Weisco/Ross/etc Pistons
Balance Shaft Removal Kit
ARP Studs
Engine Head:
1G Head
1G Intake Manifold
Tubular Exhaust Manifold
4G63 Cams
4G64 Cam Gears
1G Cam Angle Sensor
Turbo:
Ported Big 16G (for now, instaboost? will upgrade later to a GT series...)
Fuel:
Walbro 255LPH Pump
950cc or Larger Injectors
Fuel Pressure Regulator
MDS 8.5mm Wirse
NGK BPR7ES Plugs
GM Translator
3" GM Mass Airflow Sensor
DSM Link
Misc:
OEM 4G64 Timing Belt
Resurfaced Flywheel
Front Mount Intercooler
Clutch
Thus far I have collected a complete 1g head (cams, gears, etc), a Walbro 255, Turbo EPROM ECU. I will be tuning with DSMLink
I have a few questions...
I know I'll have more questions later on down the road. I'm looking for replies who have first hand experience building the 2.4L. Thanks!
-John
My Goals
Engine Block:
4G64 Block
4G64 Crankshaft
Eagle H-Beam Rods
ARP Studs
Engine Head:
1G Head
1G Intake Manifold
4G63 Cams
4G64 Cam Gears
1G Cam Angle Sensor
Turbo:
Fuel:
Walbro 255LPH Pump
MDS 8.5mm Wirse
NGK BPR7ES Plugs
GM Translator
DSM Link
Misc:
Resurfaced Flywheel
Clutch
- Will the 950cc injectors be too much? not enough? What brand do you recommend?
- What kind of CR do you think would be best? I was planning on running 8.5:1 or 8.7:1.
- What kind of AFPR should I use? Are they all basically the same?
-John
