Has any one run AN line for there coolant line to a stock turbo setup? I'm worried about clearance issues on the coolant feed hitting the wapter pipe and/or the block. If anyone has done this can you tell me what fittings you went with?
screamin'eagle said:Found the solution. For stock setup turbo is to use a 9/16 banjo to AN-6 line which will have no clearance problems. A 9/16 banjo is only 0.011 larger than 14mm. I just ordered everything i need from www.anplumbing.com to get rid of all my stock lines to the turbo and all my vaccum lines converted to AN-4. I spend just over $200 for everything.
screamin'eagle said:i actually made a spreadsheet of everything i needed. I made a line go from the intake manifold to bov, afpr and boost controller. Coolant feed and return line and also a oil feed line. I actually didn't order the fittings for the return line since the AN-10 line and fittings alone are like $50. I can get the fittings most likely for the return line for about 40CDN. So to do everything its gonna be around 250-300US to do all the engine minus fuel lines(mine already done) with AN lines.
The only thing i don't know is what thread is on the Aeromotive AFPR for the vaccum source. Its pretty small so its not 1/8NPT. Anyone have any idea?
Overkill, yes it is but is gonna look sweet and gonna be trouble free from leaks and pulling a turbo is now a 20min and installing one is even easier.
Pretty please?Boosted3000GT said:Mind hitting me up with a copy of that spreadsheet?
I'd appreciate it...
92fwdMITSU said:If you don't mind sharing your spreadsheet this is something I'm also interested in doing. Thanks
Justin B.
