1 - 2 of 7 Posts
depending on your year
tie either the Green/White, Brn/White, Brn/Blk to ground depending on your year
located behind the kick panel on the drivers side
just check the polarity and function of the wires before tapping into them to see which is correct for your car
greeneclipse said:
is the kick panel the one on the clutch pedal side (by the fuse box), or is it the one near the gas pedal where the ECU is?
and where do these wires run (to/from)? I tried looking for these a while ago, but i couldnt find them.
and one more question.....do you know where the relays are for the power windows/door locks? My passenger side PW isn't working and i want to check the relay.
thanks
by the clutch
they are in the huge mess of wires thats down there
I belive the relay for the power door locks is behind the driver, below the 6x9 speaker, under the plastic cover
You'd be best getting a service manual - as this will tell you everythin you need to know about wire/relay locations :D
1 - 2 of 7 Posts
