I am currently looking for the best external wastegate setup or the most effective one. I was looking at DSM Motorsports setup which is a stainless O2 housing with a Tial 40mm wastegate mounted on the side or the buschur setup which is an HKS mounted on a ported 2g exhaust manifold. I heard a few bad things about mounting the wastegate to the manifold because the weld itself and the metal of the manifold don't work well together which will cause it to crack and you will be re welding it every year. I like the DSM Moto. setup because it uses a stainless O2 housing which will flow more than the best ported EVO 3 housing you can find. I'll be running a BR 20G ported 2g exhaust manifold and a full buschur exhaust. I'm also going for a street setup so it's not an all out strip car. I was also looking at the setup to where you weld on a pipe to the #1 runner of the exhaust manifold and it goes around the front of the manifold to where you will attach the wastegate there. I just want to make sure I have a setup that will have somewhat of reliability.
ALL the help is appreciated thanx.
