well i have a big 16g and recently i just slapped on another housing. the one i had, had some bolts snapped off in it. so a guy from jersey sent me a new housing. well, i ported it pretty good (big enough to fit a 7 cm gasket) and also on the O2 housing side as well. with the stock solenoid i was hitting 15 psi and had no problems but that was with the old housing. but now i can't hardly hold the gas to the floor otherwise it just keeps climbing. i hooked up a manual controller but the same was happening. so i just routed the vacuum hose straight from the turbo compressor outlet straight to the wastegate (no solenoid or boost controller). now it holds to 10 psi for maybe a millisecond and keeps climbing. could the porting possibly be adding so much air that now it's overflowing the stock wastegate hole? or could there be something else i need to look for?
if the car is cold, and i have the solenoid hooked up it just shoots on up there with no hesitation. if it's warm it hits 15 but then may slowly climb on up there. with it routed straight to the wastegate it just slowly climbs up there no matter what. hmmm.....thanks for any info.
scott
p.s. it didn't start out doing this when i 1st slapped on the housing. moved from panama city, fl. to maryland though for an airforce school and since i've been up here it's started the creeping really bad. wastegate bad maybe?
scott
