I did a boost leak test today, I can hear the air passing somewhere near the throttle body. If I push down the gas the air escapes faster. I hooked up to a compressor for the test and it was slowly leaking down in pressure. I started it at about 10lbs and I could hear air in the valve cover too. I did not put the motor at TDC or anything like that. I am pretty sure the leak is in the throttle body especially since when you open it a little I can hear the air leak out more prominatly. Do I need to buy a new throttle body or are the gaskets that need replaced? I did some searching and I get mixed information.
Thanks in advance,
Mike
Thanks in advance,
Mike
