Bottom End, makin her bulletproof
8.2K views 55 replies 14 participants last post by  brians3000gt
Hey guys, some of you know I'm doing my DSM82HTA build in December. I decided while I have the mani's/head and all other bs off anyways, I might as well just go ahead and suck it up and rebuild the bottom end. I've searched on here a ton and it seems like everyone is running radically different setups for their built bottom end. So me being newer to the 4g63 I'd just like some suggestions.
I'm looking to get 30+ daily driven psi out of my new DSM82hta turbo. I'm definetly not opposed to the idea of a stroker kit, but I will be keeping the stock crank and bore of the block, this car is a 98 7 bolt at 100k with ZERO crankwalk. Before you get into the bs of building my 7 bolt, please just give me your thoughts on what pistons/rods I could run that would be beneficial to my goal of 30+ psi daily drivable bulletproof bottom end.
Thanks guys!
-Brian
What are the benefits of running a 450hp rod, on a 600whp combo? :chair:
Manley or Crowers at least... Eagle is for 30r builds... Old school.
I was looking at the Eagle rods, they look great for the money at extremepsi. I'm pretty convinced to stick with those because of they're tried and true rep. Now for pistons, what set of stroker pistons should I run? Any recommendations on that? Keep in mind that i'll be keeping the stock bore, I was checking out those 9.0:1 2.3L kit though.
Well you can paint a turd and make it look pretty, but at the end of the day, its still POS...
Good luck...
Man you guys are all over the place.
Piston selection is up to you but if you want a bulletproof bottom end:
Stock crank (balanced), stock caps, stock Bolts
Pauter X-beam rods, ACL bearings. (crosshatch the wrist pin bushings)
Whatever pistons you have swaintech race coat the tops of them.
o-ring the block and use L19 style studs.
K Mans, as always, thankyou for your endless knowledge! The only reason I haven't settled on the X-beams from Pauter is because they're almost triple the price of the Eagles. Moving on though does anyone have input on the pistons themselves?
OP. They are asking if you went with the standard 2L crankshaft or went with a longer throw 2.4L (4G64) stroker crankshaft. It sounds like you chose the 2L 4G63 crank.
Good luck with your build.
Will you be running standard ARP head studs or the stronger L19's?
I'm running Eagle/Ross 2.3 and it's holding up just fine and I'm making a few pnoies...
Best pass so far is 10.16... I have intentions on going a little faster next year without changing the bottom end...
Thanks Mac for clearing that up :) ... Read my mind. So I do have another final question (really hoping K Mans chimes in on)... Will I be ok going with the stock MLS gasket with this setup after the heads and block are decked? I'm worried that I should go with a thicker gasket. Any input on this?
#35 ·
Well mines are fine for what Im trying to do. Im only trying to make a low 400awhp pump gas car when the hx40 goes on. I will never run at or above 30psi, nor aggressive timing due to 93oct limitations, so with the orings I wont be stretching anything.
But Link to this?
