BPR7ES or BR7ES?
1 reading
4.7K views 4 replies 5 participants last post by  Van
I was told to use BR7ES and that is what i currently have now but my plugs are fouled...... so it is time for new ones should i stay with the BR7ES or are BPR7ES fine too? What the hell is the difference? I heard something like the BPR has a longer electrode and can be blow out buy higher boost? I hear alot of people running the BPR's and was wondering y i was told to get Br's? MY mods are listed below...
thanks........
Definetely go with the BPR7ES. These are the plugs that most of us use here. For one I have nver heard about using the BR7ES on these cars. By the way the stcok plug is the BPR6ES, the BPR7ES is one range colder and helps a lot when you have a bigger turbo and running high psi on it.
Checkhttp://www.extrememotorsports.com
for a FAQ on the NGK plugs.
It all depends on what boost you are trying to run. 17 or more PSI? Then go with the BPR7ES, anything lower and the 6ES will be fine.
