Broken Lowercontrol arm/spindle
852 views 3 replies 3 participants last post by  barney
It was wet, i hit a curb, broke some stuff in the right front, does anyone know if the AWD suspension changes for 1st Gen's?
I have an early production 1992 AWD Eclipse, will any of the front suspension from 1st gen AWD's work or do i have to get the same year and such? Thanks
Well, the big brakes are a popular swap. If you smacked the curb hard enough you may want to have a body shop check the mounting points for the front and rear bushings for the lower control arm. They may have moved. Also, the strut may be toast and the bearing at the top of the strut. As for the suspension parts from all 1G years, they, as far as I know, are the same.
