can someone spot check my timing marks?
9.8K views 34 replies 15 participants last post by  op712
I'm doing my first timing belt and I think i've got it on pretty good from all the posts i've read.
I got it tensioned so that the grenade pin still goes into the hole on the tensioner freely, and all the timing marks line up after rotating the engine 6 times and letting it sit 15 minutes (actually overnight).
I wanted someone to look at the pics of the timing marks to spot check my work though. Everything looks spot on except the two camshaft timing marks are maybe 1/4 to 1/2 tooth off. See the attached picture of the camshaft alignment... i'll upload more pics if that isn't clear enough.
Thanks!
-Martin
#28 ·
White91GSX said:
no your wrong BEFORE you put the timing belt on the exhaust should be one tooth behind and it will straighten its self but his belt is alreayd on therefor he is a tooth off
what ever it alost cause to argue with you. go blow your shit up. i bet here motor starts just fine
#29 ·
There is really no arguments here, you'r incorrect, the marks must line up after exactly as shown in VFAQ.....unlike the OP's original pictures.
Being one tooth off will not prevent the motor from starting up nor will it "blow your shit up". If you're just going to throw out non-sensor because someone disagrees with you, please stay out of the discussion. This issue is too important to be ignored, many people make the same exact mistake like myself on my first timing belt job, I ran my car one tooth off for an entire year without even knowing it. Bottom line, if you have to question whether marks line up, they're off.
#30 ·
It's not that hard to make sure everything is spot on while your installing the belt. As you put the belt on each sprocket turn it and make sure it doesn't move without the others moving too. I usually back up the sprocket part of a tooth to get the belt on and then pull it tight checking to make sure the timing mark lines up and move to the next. The only slack then that will be left is between the crank and exhaust the tightening the tensioner pully won't cause anything else to move.
After doing the 6G72 belts the 4G63 belt is a breeze.
Steve
#31 ·
( I know this is an old thread, but a question still arises: ) Where he used the larger drillbit, thus causing the tension pulley to be more drawn in towards the right, wouldn't this cause the marks on the exhaust cam sprocket to be more pulled forward to the left, thus going out of line with the intake marks?
#32 ·
No.
The belt doesn't stretch to speak of so the relationship between the sprockets is maintained if there wasn't slack between them when the belt is tensioned.
The only slack in the belt when you correctly install it is between the crank and exhaust cam, and that's what adjusting the tensioner pulley takes up. Once that slack is gone any additional rotation of the tensioner pulley causes the tensioner arm to move which loads the auto-tensioner and belt. If you had improperly installed the belt the timing marks would shift as soon as you started tensioning the belt.
The clearance between the tensioner arm and the body of the auto-tensioner changes the range of motion that the tensioner arm can move but it doesn't change the timing marks.
#33 ·
HI again - thx for the help on this .. makes excellent sense.
Another question: the timing belt sprocket - does that have to be pulled off with a puller, or does it just slip off the crankshaft after removing the end bolt so one can get to the balance belt assembly?
(my first experience with the 4G63 - even though I've done DOHC engines before with belt changes ..)
thx-Op712
#35 ·
Thx for the help on this, for I'm getting a '90 Ply RS Turbo in very good condition. Body needs a bit of help (a push-in goose egg dent on the passenger quarter panel that's an easy pushout, and numerous door dings) with some body work and repaint, the interior looks almost new-driver's seat with very little entrance wear, but the classic headliner falldown-needs to be recovered or replaced.
Motor runs super smooth along with the turbo, BUT as with any vehicle with high mileage (161k) is to get the thing home and immediately do the belts, for I heard plenty of horror stories in these forums of busted or mistimed belts that suddenly destroys the 4G63 motor.
Big one that I recently heard is that two guys doing a belt change on a 4G63: Got the belts in and one guy with the wrench begins to turn the motor around to seat the belts, but noticed that the crank was suddenly horribly hard to turn with the wrench, yet he kept turning to do the six revolution requirement. The other guy asked him about the stiffness of the wrench and immediately knew that every valve was bent due to the belt wasn't positioned correctly - and just by doing the wrench turn, did the number on the valves.
Thus with hearing this begins a tip to all: If you do the socket wrench turn to chek belts, if you feel any sudden resistance in the wrench, you got a valve in the way of a rising piston and they are meeting in an unfortunate and forbidden area - being interference motors.
thx-Op.712
