1 - 8 of 8 Posts
bigolsen
Ok so I just got dsmlink and am trying to dial in the LTFT by adjusting the deadtime like the instructions state.
I can't seem to get the idle values out of the negative and I'm thinking it is because I don't have an adjustable fpr yet, but Ive only got the walbro 190.
I started out by logging with the defaults for my fic650's which are:
Deadtime: 315
Global: -31%
Which turned out: +0.5% cruising
-8.7 idle
then tried 300 DT
and global -32% for:
+1.3 cruising
-6.8 idle
" " 285 DT
-32% +3.7 cruising
-8.0 idle
255DT
-31% +2.1 cruise
-9.5 idle
It seems I can't get close to the +/- 5% difference between cruising and idle trims that I should so I guess I'm better off sticking with the base settings for my injectors untill I can adjust base fuel pressure. DSMlink states that if Idle ltft is lower than cruise to remove deadtime which is what I did and in the end made the computer pull more and more fuel out at idle.
So is it ok for me to move on to WOT logging so I know if I can tweak fuel and timing variables for more power??
FYI: I just installed a 1g throttle body ported to 63MM prior to having dsmlink. Maybe that could be causing a rich idle??
Any suggestions from experienced dsmlinkers would be greatly appreciated.
Thanks.
Something isn't right, those setting are usually right on? I havent had to much time to play with my link but I know when I first installed it I didn't have to touch anything as far as low throttle and cruising.. Perfect 14.9afr, maybe it does have something to do with the t/b but somethings causing you to run really rich.. Sorry I cant be more help, have you tryed posting on the link/forums?
Changing the deadtime will adjust LTFT lo and mid in an inverse fashion. One will go up while the other goes down.
From the original -31%, 315 deadtime setting, all you needed to do was adjust the LTFT lo (idle) value and leave the LTFT mid value alone. Bringing down the 50Hz slider down around 6-7% should have done the trick.
Read this for more info http://www.jeffgst.com/gmafcalibration2.html
Discussion starter · #5 ·
I was wondering about that but I read posts that said don't touch anything untill ltft's are good and the dsmlink instructions only say to adjust the deadtime to change the ltft trims. I will try what you said. I just don't know why my idle trim could be so screwy when I'm running the stock mass.
Thanks a ton.
bigolsen said:
Ok after setting the maf 50hz slider to -7 I got these readings which i think are pretty in line:
Mid still good: -1.1%
lo (idle): -0.5%
What do ya think?
Pretty amazing, huh??;)
That is why I wrote my method on my website, since it is not in the DSMlink manual. It just works and I know it has helped hundreds of DSMlink users. I am up to 7000 hits a month on my site.
Discussion starter · #8 ·
Yah thanks alot. They should have this info with DSMlink for when you cant get trims right from just changing deadtime. I'm glad you know your stuff.
Thanks.
1 - 8 of 8 Posts
