today driving home from a new years party (yea what a great day for this to happen) i was at about 45 just cuising and my car shut off. I pulled over, tried to start it and nothign was getting power, i went checked battery connections, fuses ect and my ignition fuse was blown. After seeing that, i put a new fuse in and the car would turn over but not start. When turning over, the car will turn over a few times than it makes a noise and stops turing over, the noise seems to be coming from the starter area. AFter trying to start my car a few times i blew another fuse. We tried push starting it to no avail. I'm assumeing my starter is causing the car not to start, although it does turn over the motor but than seems to get "stuck", but i find it weird that my car would die while driving (starter shouldn't cause that) and now it also won't start.
if it matters any, i did install a walbro fuel pump today and my car was runnign fine earlier, anything i should look at besides the fuel pump? i'm looking for stuff to look for when i tow my car home tomrrow. any ways to check for anything besides getting a new fuse and turning the key in the on posistion and seeing if the pump is getting power? I'm lost because these 2 seemingly different problems happened at the same time.
