My car starts when cold but will die only after about a min (the check enginge light is on). The car cannot be restarted right away, all it does is turnover. There is no spark. But if you leave it for a while you can start it up again but the same thing will happen.
The car was running fine last week and this problem suddenly occured. This problem is on my 91 Awd.
Codes from apocketlogger read: 14 Throttle Postion Sensor, 22 Crank Angle Sensor, 23 TDC Sensor.
Is 22 & 23 the same senor? If not what is the diffence and what are they (what do they look like)?
