If I hook up an oil catch can between the intake tube and valve cover breather is that the proper way? Also if I do it that way does it matter if the catch can has a little air filter on it?
If only one CC
PCV->IM
Breather -> CC -> intake pipe.
Oil in IM = No big deal.
Oil in IC = Very big deal.
If use 2nd CC
PCV -> 2nd CC -> check valve -> IM = clean IM and no leaky PCV.![]()
Hate to bring this thread up but i am trying to route my vacuum lines correctly and wanted to know if the 2nd catch can is necessary? The one that runs the valve cover hose with the pcv to the catch can then to the check valve and to the intake manifold? If 2nd catch can is not needed can i just route the pcv valve to the intake like factory?Proper way*
Basically, you need the check valve in between the Intake Manifold and PCV. Also, a vacuum source (typically the intake pipe) is important to relieve crankcase pressure and reduce blowby under boost.
Correct the pcv is a check valve, a very shatty one at that. Aftermarket ones are often bad out of the box, and oem ones can go bad after a few thousand miles. Definitely have to have a us plastics check valve or some sort of check valve in place.The pcv is a check valve, its just a ball and spring in a tube.
