It looks like a nightmare according to some of the posts I read....
Will I strip something as a given?
Thanks
Thanks
eagletalonawd said:The 2g fuel filter is farther down on the firewall than the 1g. When you remove EVERYTHING it is still hard to get to. I pulled the Batt, batt tray, etc. The way I finally got it loose from the bottom was to put some vice grips on the fuel line fitting, then used an open end wrench on the filter. Man that sucked.![]()
