I've read a buncha threads on this topic, but I can't figure out what my problem is.
I've had this problem before where my clutch pedal catch point would move, in the past, just re-adjusting the pedal height would fix it.
But now it seems like i have to adjust it after any long drive. It doensnt seem to move in one specific direction either. If I adjust it so that the catch point is closer to the floor, it moves towards the floor, but if I adjust it so the point is higher to the top of the pedal it moves that way. I checked my fluid level and it seems ok, and I dont think its leaking(the slave is wet, but only the actualy cylinder)
Do you think I just need to bleed the clutch? or do I need to replace one of the cylinders??
