Ok I am interested in running e85 i have 1600cc injectors and a single 255 pump. Am i going to have enough fuel to run 35 pounds on my 20g. I know e85 requires 30% more fuel..
This is excellent advice.Yes you will be fine, as long as you have an AFPR. The injectors are big enough where you can get away with a single walbro 255 on E85. Id recommend lowering the base fuel pressure to somewhere around 30-32psi and start from there.
