I'm removing the engine in my 92 Eclipse (non-turbo), first time doing, have questions.
I assuming I can leave my axles in and just unbolt the engine from the tranny (While supporting the tranny) and pull it up and out?
Do I need to drain the tranny? Is there a gasket/o-ring between the engine/tranny I can/should change since it's right there?
Is dropping the engine in as easy as it seems - I just lower it, bolt up the motor mounts, then connect all the electrical/vacuum lines? I don't need to remove the rad or anything I assume?
Any tips? Tricks? etc... would be more than appreciated.
Oh - and I have the head taken off the car already (Was going to just do the head but there's a hole in a piston). How will I raise the old engine out - just throwing a chain around the motor mounts and lifting?
