1 - 2 of 17 Posts
Have Jeff at DSMchips just do a reflash on it to your liking. It's 20.00 dollars only. Whats nice is that, based on your mods you can have Jeff insert them. I wouldn't run the TMO if you don't know its preferences, since it will be very harmful to your motor. ex=(chip program for 660cc when you are using 450cc stock, 2G mas when your using 1G mas.)
When you get a reflash for your chip, you don't even need a safc. Since Jeff from DSMchips flashed the chip, everything should be perfect. Don't use the safc, as you can mess up the base tuning on the chip. If you have more questions, you should contact Jeff at DSMchips. ( this is what I was told, which makes sense.) So i wont be investing into a SAFC, since it's just more money down the drain. SAFC is the old way, especially when you have DSMlink and other tuning devices at your footstep.
1 - 2 of 17 Posts
